trendminer.views.views module¶
This module only contains the class Views
class
trendminer.views.views.Views(trend_miner_client: trendminer.trendminer_client.TrendMinerClient)¶ -
Bases:
objectClass to interface with TrendMiner views
load_view(view_id: str, layer_ids: [<class 'int'>] = None) → [<class ‘pandas.core.frame.DataFrame’>]¶ -
Loads the time series data of a view into a list of Pandas DataFrames. One DataFrame is returned per layer in the view. Each DataFrame can have a different set of tags available. The optional parameters layer_ids allows you to only load a specified list of layers (identified by the layer ids, as provided by the view_info function).
- Parameters
view_id – Id of the view to load (mandatory)
layer_ids – Optional list of layer ids of the layer to load
- Returns
A list of Pandas DataFrames, one for each (selected) layer
view_info(view_id: str) → trendminer.views.view_info.ViewInfo¶ -
Collect information about a view based on its ID. This info can be used to fetch data from a view: it lists all the layers that are included in the view. When fetching data from the view you can make a selection of layers to be included in the data.
- Parameters
view_id – ID of the view for which info is collected
- Returns
A ViewInfo object, giving an overview of the included tags and layers in the requested view.
- Raises
ViewNotFoundException – If the view is unknown to TrendMiner
UnauthorizedException – If the authentication failed
TrendMinerException – Any other failure while communication with TrendMiner
TimeSeriesNotFoundException – If a time series from the view cannot be found in TrendMiner
TimeSeriesNotAccessibleException – If a time series from the view is not accessible for you in TrendMiner
AssetAttributeNotFoundException – If an attribute from the view cannot be found in TrendMiner
AssetAttributeNotAccessibleException – If an attribute from the view is not accessible for you in TrendMiner
- Returns
Parsed view info
